주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Motorola Slvr L7 Keypad Replacement
필요한 것
  1. Motorola Slvr L7 Keypad Replacement, Keypad: 1 단계, 이미지 1/1
    • Push down on the black tab located at the top center of the Motorola phone
  2. Motorola Slvr L7 Keypad Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pulling the battery from the top center
  3. Motorola Slvr L7 Keypad Replacement: 3 단계, 이미지 1/1
    • Remove the four (4) T6 Torx screws from the rear metal plate.
  4. Motorola Slvr L7 Keypad Replacement: 4 단계, 이미지 1/2 Motorola Slvr L7 Keypad Replacement: 4 단계, 이미지 2/2
    • Insert the flat end of a spudger and pry the metal cover up off the phone
  5. Motorola Slvr L7 Keypad Replacement: 5 단계, 이미지 1/2 Motorola Slvr L7 Keypad Replacement: 5 단계, 이미지 2/2
    • Carefully, disconnect the two connectors from their sockets on the motherboard using the flat end of a spudger.
  6. Motorola Slvr L7 Keypad Replacement: 6 단계, 이미지 1/1
    • Use a spudger to pry the antenna cable connectors from its respective socket on the motherboard.
    • De-route the antenna cable by pulling it out.
  7. Motorola Slvr L7 Keypad Replacement: 7 단계, 이미지 1/1
    • Starting at one side, use a spudger to lift and remove the black plastic screw cover at the bottom of the phone near the speaker
    • The cover is attached by several clips, so some force may be required, especially to unclip the first clip.
    • Be careful not to loose the round plastic piece that covers the microphone.
  8. Motorola Slvr L7 Keypad Replacement: 8 단계, 이미지 1/2 Motorola Slvr L7 Keypad Replacement: 8 단계, 이미지 2/2
    • Remove the 2 newly exposed T6 screws
  9. Motorola Slvr L7 Keypad Replacement: 9 단계, 이미지 1/2 Motorola Slvr L7 Keypad Replacement: 9 단계, 이미지 2/2
    • Starting at the top, insert the flat end of a spudger and pry the frame of the phone.
    • The frame is attached by several clips, so some force may be required to dislodge the first clip.
    • Work your tool around the entire edge of the phone, moving as soon as you hear a clip come undone, to avoid breaking the frame.
  10. Motorola Slvr L7 Keypad Replacement: 10 단계, 이미지 1/2 Motorola Slvr L7 Keypad Replacement: 10 단계, 이미지 2/2
    • Carefully, Insert the flat end of a spudger and pry the keyboard up off the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jorge Trujillo
회원 가입일: 05/19/11
520 평판
안내서 4개 작성하였습니다
CSU Los Angeles, Team 1-1, Nelson Spring 2011 CSU Los Angeles, Team 1-1, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G1
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 5,699
