주요 콘텐츠로 건너뛰기
Motorola Talkabout FV700R Speaker Replacement
필요한 것
  1. Motorola Talkabout FV700R Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back battery cover by pressing the tab to the left, and lifting.
    • A small screwdriver can aid this process.
    Gostaria de saber se eu tenho como encontrar a placa para fazer a troca, tenho um rádio da Motorola t400
    mauropessoa - 답글
  2. Motorola Talkabout FV700R Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the batteries currently in the radio.
    • When you're ready to add new batteries, place Ni-MH or AAA replacement batteries in the specified slots.
    • The orientation of the batteries is specified in the battery compartment.
  3. Motorola Talkabout FV700R Speaker Replacement, Volume Knob: 3 단계, 이미지 1/1
    • Turn the Volume knob to the off position.
  4. Motorola Talkabout FV700R Speaker Replacement: 4 단계, 이미지 1/2 Motorola Talkabout FV700R Speaker Replacement: 4 단계, 이미지 2/2
    • Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
    • This may require some twisting and force.
  5. Motorola Talkabout FV700R Speaker Replacement, Front Faceplate: 5 단계, 이미지 1/1
    • Remove the four 3 millimeter T6 Torx screws from the front of the radio.
  6. Motorola Talkabout FV700R Speaker Replacement: 6 단계, 이미지 1/2 Motorola Talkabout FV700R Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the four 3 millimeter T8 Torx screws from the back of the radio.
  7. Motorola Talkabout FV700R Speaker Replacement: 7 단계, 이미지 1/3 Motorola Talkabout FV700R Speaker Replacement: 7 단계, 이미지 2/3 Motorola Talkabout FV700R Speaker Replacement: 7 단계, 이미지 3/3
    • Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
    • Be careful, as the antenna is still attached. Pulling the two sides apart too quickly could break the antenna.
  8. Motorola Talkabout FV700R Speaker Replacement: 8 단계, 이미지 1/2 Motorola Talkabout FV700R Speaker Replacement: 8 단계, 이미지 2/2
    • Gently pull the circuit board away from the front faceplate.
    • Be careful not to tug the wire connecting the circuit board to the speaker, as it is still attached to the faceplate.
    • Do not touch the the button contacts on the circuit board (the button contacts are shown in the red box of the second picture). This can cause long-term damage to the radio unless you properly clean them (see Repairing Motorola TALKABOUT FV700 Two Way Radio Button Contacts Guide).
  9. Motorola Talkabout FV700R Speaker Replacement, Speaker: 9 단계, 이미지 1/3 Motorola Talkabout FV700R Speaker Replacement, Speaker: 9 단계, 이미지 2/3 Motorola Talkabout FV700R Speaker Replacement, Speaker: 9 단계, 이미지 3/3
    • To remove the speaker from the faceplate, insert a paperclip through the front faceplate and push.
    • The speaker is glued to the front faceplate, so it may take some force to remove the speaker.
  10. Motorola Talkabout FV700R Speaker Replacement: 10 단계, 이미지 1/3 Motorola Talkabout FV700R Speaker Replacement: 10 단계, 이미지 2/3 Motorola Talkabout FV700R Speaker Replacement: 10 단계, 이미지 3/3
    • Now the circuit board can be removed from the back faceplate.
    • To do this, grip the back faceplate in one hand and the antenna in the other. Pull and twist the antenna away from the back faceplate. The circuit board should be removed with the antenna, as they are attached.
  11. Motorola Talkabout FV700R Speaker Replacement: 11 단계, 이미지 1/1
    • Observe the orientation of the speaker as it is removed, so that the new speaker can be installed to face the same way as the old one that you are removing.
    • You should end up with just the circuit board and speaker, as seen in the picture.
  12. Motorola Talkabout FV700R Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the wires connecting the speaker to the circuit board with a soldering iron.
    • The new speaker wires can then be connected to the circuitboard with a soldering iron.
    • Be careful when working with a soldering iron, as it can easily cause burns.
    • Make sure the new speaker is connected in the same orientation as the old speaker.
결론
Kayla Brennan
회원 가입일: 03/26/14
737 평판
안내서 6개 작성하였습니다
Clemson, Team 6-4, Benson Spring 2014 Clemson, Team 6-4, Benson Spring 2014 회원
CLEM-BENSON-S14S6G4
3 회원들
안내서 7개 작성하였습니다
댓글 3개
thank you very much!!!!!!!!
deskjet27 - 답글
What glue is used to reattach speaker to front housing?
Jason Schlager - 답글
Speaker model#?...?
Jorge - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 4,343
