주요 콘텐츠로 건너뛰기
Motorola Triumph Charger port Replacement
필요한 것
  1. Motorola Triumph Charger port Replacement, Charger port: 1 단계, 이미지 1/1
    • Follow the steps in the battery guide and in the speakers guide to pull the mother board from the device chassis.
    • On the other side of the marker you will find the charger port.
    • To remove, you must desolder the four contact points on the motherboard.
    • When adding the new charger port, resolder the new charger port to the four contact points.
결론
greg
회원 가입일: 10/07/14
12 평판
안내서 5개 작성하였습니다
USF Tampa, Team 7-5, Leahy Fall 2014 USF Tampa, Team 7-5, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G5
3 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 275
