주요 콘텐츠로 건너뛰기
Motorola V180 Motherboard Replacement
필요한 것
  1. Motorola V180 Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Motorola V180 Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Motorola V180 Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Completely power off the Motorola V180.
    • Flip the phone over to its back side.
    • Press down the button and slide off the back cover.
    • Remove the old battery.
  2. Motorola V180 Motherboard Replacement, Motherboard: 2 단계, 이미지 1/3 Motorola V180 Motherboard Replacement, Motherboard: 2 단계, 이미지 2/3 Motorola V180 Motherboard Replacement, Motherboard: 2 단계, 이미지 3/3
    • Power off the Motorola V180.
    • Hold down the button and slide off the back cover.
    • Remove the battery.
  3. Motorola V180 Motherboard Replacement: 3 단계, 이미지 1/3 Motorola V180 Motherboard Replacement: 3 단계, 이미지 2/3 Motorola V180 Motherboard Replacement: 3 단계, 이미지 3/3
    • Use your T6 Torx Screwdriver to unscrew the four screws located on the back of the phone.
    • Remove the SIM card located on the back of the phone.
    • A ribbon near the antenna is still attached to the motherboard. Do not break this ribbon.
  4. Motorola V180 Motherboard Replacement: 4 단계, 이미지 1/2 Motorola V180 Motherboard Replacement: 4 단계, 이미지 2/2
    • Unclip the pronged rectangle connector ribbon attached to the motherboard.
    • Remove the motherboard.
결론
Tyler Knisley
회원 가입일: 05/07/10
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 6-16, Maness Spring 2010 Cal Poly, Team 6-16, Maness Spring 2010 회원
CPSU-MANESS-S10S6G16
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,982
