주요 콘텐츠로 건너뛰기
Motorola V190 Mini-USB Port/Motherboard Replacement
필요한 것
  1. Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: 1 단계, 이미지 1/2 Motorola V190 Mini-USB Port/Motherboard Replacement, Antenna: 1 단계, 이미지 2/2
    • Rotate the antenna counter-clockwise until the antenna is completely removed.
  2. Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: 2 단계, 이미지 1/2 Motorola V190 Mini-USB Port/Motherboard Replacement, Battery: 2 단계, 이미지 2/2
    • Press the button at the bottom of the back cover.
    • Pull the back cover down.
    • Remove the battery.
    • Our device is missing the battery.
  3. Motorola V190 Mini-USB Port/Motherboard Replacement, Mini-USB Port/Motherboard: 3 단계, 이미지 1/1
    • Use the TR6 Torx Security Screwdriver to remove the four 6.3mm Torx screws on the back.
  4. Motorola V190 Mini-USB Port/Motherboard Replacement: 4 단계, 이미지 1/3 Motorola V190 Mini-USB Port/Motherboard Replacement: 4 단계, 이미지 2/3 Motorola V190 Mini-USB Port/Motherboard Replacement: 4 단계, 이미지 3/3
    • Use the iFixit opening tool to pry open the crevice at the top of phone.
    • Use the same tool to pry open the crevice at the bottom of the phone.
    • At this time, do not separate the ribbon from the motherboard at the bottom of the phone.
  5. Motorola V190 Mini-USB Port/Motherboard Replacement: 5 단계, 이미지 1/3 Motorola V190 Mini-USB Port/Motherboard Replacement: 5 단계, 이미지 2/3 Motorola V190 Mini-USB Port/Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the black rubber piece from the top of the motherboard.
    • Disconnect the rectangular ribbon from the motherboard.
    • Remove the motherboard.
결론
Michael Pollock
회원 가입일: 08/28/19
545 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 4
전체 시간: 179
