주요 콘텐츠로 건너뛰기
Motorola V2397 Motherboard/Screen Replacement
필요한 것
  1. Motorola V2397 Motherboard/Screen Replacement, Battery: 1 단계, 이미지 1/3 Motorola V2397 Motherboard/Screen Replacement, Battery: 1 단계, 이미지 2/3 Motorola V2397 Motherboard/Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Press and hold the button on the battery cover
    • Pull the battery cover down and out to remove it
  2. Motorola V2397 Motherboard/Screen Replacement: 2 단계, 이미지 1/2 Motorola V2397 Motherboard/Screen Replacement: 2 단계, 이미지 2/2
    • Remove the batteries by pulling them away from the phone
  3. Motorola V2397 Motherboard/Screen Replacement, Back Cover: 3 단계, 이미지 1/2 Motorola V2397 Motherboard/Screen Replacement, Back Cover: 3 단계, 이미지 2/2
    • Using the Torx T4 screwdriver remove the six screws highlighted in the picture to the left
  4. Motorola V2397 Motherboard/Screen Replacement: 4 단계, 이미지 1/2 Motorola V2397 Motherboard/Screen Replacement: 4 단계, 이미지 2/2
    • Use your fingers or a spudger to remove the back cover
  5. Motorola V2397 Motherboard/Screen Replacement, Phone: 5 단계, 이미지 1/2 Motorola V2397 Motherboard/Screen Replacement, Phone: 5 단계, 이미지 2/2
    • Place your plastic opening tool in between the motherboard and the front cover of the phone
    • Apply a small force to lift the motherboard away from the front cover
  6. Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: 6 단계, 이미지 1/2 Motorola V2397 Motherboard/Screen Replacement, Motherboard/Screen: 6 단계, 이미지 2/2
    • Use your fingers to unhook the highlighted plastic frame of the screen from motherboard
    • Carefully separate the screen from the motherboard
    • Note the cable connecting the screen to the motherboard. Do not pull the screen too far from the motherboard or you may damage the cable
  7. Motorola V2397 Motherboard/Screen Replacement: 7 단계, 이미지 1/2 Motorola V2397 Motherboard/Screen Replacement: 7 단계, 이미지 2/2
    • Lift the flap of the connector on the motherboard using a spudger
    • Carefully remove the FFC cable from the connector
    • The screen should now be free from the motherboard
결론
Chris
회원 가입일: 01/13/15
501 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-6, Sullivan Winter 2015 USF Tampa, Team 1-6, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G6
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 159
