이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Installing a new flex cable for the Motorola V276 phone.
필요한 것
Locate the silver button on the back of the phone, near the bottom.
Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
Now that the battery is exposed, use your fingers to remove the it from the phone.
Note the metal connections on the phone, which are now exposed with the battery removed.
There are corresponding metal connectors on the replacement battery.
When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
