소개
This is a guide for replacing the back speaker for a Motorola V276 phone.
부품
지정된 부품이 없습니다.
Locate the silver button on the back of the phone, near the bottom.
Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
Note the metal connections on the phone, which are now exposed with the battery removed.
There are corresponding metal connectors on the replacement battery.
When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
거의 끝나갑니다!
결론
