주요 콘텐츠로 건너뛰기
Motorola V325 External Casing Replacement
필요한 것
  1. Motorola V325 External Casing Replacement, External Casing: 1 단계, 이미지 1/3 Motorola V325 External Casing Replacement, External Casing: 1 단계, 이미지 2/3 Motorola V325 External Casing Replacement, External Casing: 1 단계, 이미지 3/3
    • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
    • Lift the panel off of the phone.
  2. Motorola V325 External Casing Replacement: 2 단계, 이미지 1/3 Motorola V325 External Casing Replacement: 2 단계, 이미지 2/3 Motorola V325 External Casing Replacement: 2 단계, 이미지 3/3
    • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  3. Motorola V325 External Casing Replacement: 3 단계, 이미지 1/2 Motorola V325 External Casing Replacement: 3 단계, 이미지 2/2
    • Unscrew the four screws using the T6 Torx Screwdriver.
  4. Motorola V325 External Casing Replacement: 4 단계, 이미지 1/3 Motorola V325 External Casing Replacement: 4 단계, 이미지 2/3 Motorola V325 External Casing Replacement: 4 단계, 이미지 3/3
    • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
결론
Minh Tran
회원 가입일: 01/15/10
2 평판
안내서 2개 작성하였습니다
Cal Poly, Team 4-15, Forte Winter 2010 Cal Poly, Team 4-15, Forte Winter 2010 회원
CPSU-FORTE-W10S4G15
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 11
전체 시간: 2,098
