주요 콘텐츠로 건너뛰기
Motorola V325 Screen and External Display Disassembly
필요한 것
  1. Motorola V325 Screen and External Display Disassembly, External Casing: 1 단계, 이미지 1/3 Motorola V325 Screen and External Display Disassembly, External Casing: 1 단계, 이미지 2/3 Motorola V325 Screen and External Display Disassembly, External Casing: 1 단계, 이미지 3/3
    • Remove the rearmost panel by pushing down on the silver button, then simultaneously pulling downward on the panel.
    • Lift the panel off of the phone.
  2. Motorola V325 Screen and External Display Disassembly: 2 단계, 이미지 1/3 Motorola V325 Screen and External Display Disassembly: 2 단계, 이미지 2/3 Motorola V325 Screen and External Display Disassembly: 2 단계, 이미지 3/3
    • Using your thumbnail or a thin flat head screwdriver, peel back the screen protector on the inside of the phone: It is only held on by glue but may take a good amount of force to be removed.
  3. Motorola V325 Screen and External Display Disassembly: 3 단계, 이미지 1/2 Motorola V325 Screen and External Display Disassembly: 3 단계, 이미지 2/2
    • Unscrew the four screws using the T6 Torx Screwdriver.
  4. Motorola V325 Screen and External Display Disassembly: 4 단계, 이미지 1/3 Motorola V325 Screen and External Display Disassembly: 4 단계, 이미지 2/3 Motorola V325 Screen and External Display Disassembly: 4 단계, 이미지 3/3
    • Peel back the screen protector frame. Close phone at the hinge, then pull off the front outer casing.
  5. Motorola V325 Screen and External Display Disassembly, Motorola V325 Screen and External Display Disassembly: 5 단계, 이미지 1/2 Motorola V325 Screen and External Display Disassembly, Motorola V325 Screen and External Display Disassembly: 5 단계, 이미지 2/2
    • After removing the external casing, there are no more screws holding on the gray metal plate. Carefully separate the gray plate from the rest of the phone by simply lifting it off.
  6. Motorola V325 Screen and External Display Disassembly: 6 단계, 이미지 1/3 Motorola V325 Screen and External Display Disassembly: 6 단계, 이미지 2/3 Motorola V325 Screen and External Display Disassembly: 6 단계, 이미지 3/3
    • Next separate the screen from the phone, pulling it away slowly as it will still be attached by a yellow ribbon.
    • A yellow ribbon attaches to the area boxed in blue. Unclip the yellow ribbon from the circuit board using your fingers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Danny Breslow
회원 가입일: 01/14/10
19 평판
안내서 1개 작성함
Cal Poly, Team 4-15, Forte Winter 2010 Cal Poly, Team 4-15, Forte Winter 2010 회원
CPSU-FORTE-W10S4G15
5 회원들
안내서 8개 작성하였습니다
댓글 한 개
This was SO very helpful! I had dropped my V325 phone the other day and when I opened it, the screen was dark :( However, it still dialed and received calls so I was HOPING that a connection to the screen was the issue. Following this guide, I was able to get to the back of the display and sure enough, a connection was out of place. Put it back together and everything is working great!
Thanks so much!
Bob
Bob - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,822
