주요 콘텐츠로 건너뛰기
Motorola V551 Circuit Board Replacement
필요한 것
  1. Motorola V551 Circuit Board Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola V551 Circuit Board Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
  2. Motorola V551 Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Lever the battery out by pressing upwards on the bottom corners of the battery.
  3. Motorola V551 Circuit Board Replacement, Circuit Board: 3 단계, 이미지 3개 중 1개 Motorola V551 Circuit Board Replacement, Circuit Board: 3 단계, 이미지 3개 중 2개 Motorola V551 Circuit Board Replacement, Circuit Board: 3 단계, 이미지 3개 중 3개
    • Remove the rubber screw covers using a plastic spudger.
    • Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
  4. Motorola V551 Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Unscrew the antenna.
  5. Motorola V551 Circuit Board Replacement: 5 단계, 이미지 3개 중 1개 Motorola V551 Circuit Board Replacement: 5 단계, 이미지 3개 중 2개 Motorola V551 Circuit Board Replacement: 5 단계, 이미지 3개 중 3개
    • Gently release the two latches using an opening tool.
    • The plastic latches are very fragile. Don’t use excessive force or they might break.
    • Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
    • Lift the back panel off of the phone.
  6. Motorola V551 Circuit Board Replacement: 6 단계, 이미지 2개 중 1개 Motorola V551 Circuit Board Replacement: 6 단계, 이미지 2개 중 2개
    • Loosen the copper circuit board connection with an opening tool.
    • Gently lift the copper connection.
  7. Motorola V551 Circuit Board Replacement: 7 단계, 이미지 3개 중 1개 Motorola V551 Circuit Board Replacement: 7 단계, 이미지 3개 중 2개 Motorola V551 Circuit Board Replacement: 7 단계, 이미지 3개 중 3개
    • Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
    • Gently lift the motherboard off of the front panel.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
gregatron
회원 가입일: 10/29/09
105 평판
안내서 6개를 작성함
Cal Poly, Team 6-6, Maness Fall 2009 Cal Poly, Team 6-6, Maness Fall 2009 회원
CPSU-MANESS-F09S6G6
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 3,288
