이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
Lever the battery out by pressing upwards on the bottom corners of the battery.
Remove the rubber screw covers using a plastic spudger.
Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
Gently release the two latches using an opening tool.
Pry off the back panel by wedging an opening tool into the crevice between the back panel and the circuit board.
Lift the back panel off of the phone.
Loosen the copper circuit board connection with an opening tool.
Gently lift the copper connection.
Lift up and pull out the pressure pad from under the buttons on the side of the chassis.
Gently lift the motherboard off of the front panel.
다른 3명이 해당 안내서를 완성하였습니다.
