소개
This guide is for replacing a key on the keypad. Super glue is required.
필요한 것
Press down on the chrome button on the bottom of the chassis. Simultaneously slide the back cover down, away from the phone.
Remove the rubber screw covers using a plastic spudger.
Use a T6 Torx screwdriver to remove the screws underneath the rubber screw covers.
Gently squeeze the bottle of super glue so that only a small amount (about 1/3 pinky width) is a applied to the back side of the key.
다른 한 분이 해당 안내서를 완성하였습니다.
