소개
If you find that your Motorola V557 camera is not working properly, this guide will walk you through the steps to replace it. We will be replacing the entire camera along with the ribbon connecting it to the phone. A nonfunctioning camera may not show any picture on the screen or show a poor or unclear image. This would indicate that the camera needs to be repaired. This guide requires that the battery be below 25% for the safety of the repairer. No complicated skills or tools are needed for this repair. In order to complete this repair, tactile ability and hand tools are required. If this repair is done correctly your camera function should be restored and clear images will show up on the screen.
필요한 것
First, on the back of the phone find the silver button on the top left corner of the phone.
Simultaneously push down the button and slide the back plate down to reveal the battery.
Remove the four rubber stoppers from around the screen with a pin to reveal four screws.
Gently peel off the plastic film from the metal plate above the camera lens as shown.
다른 2명이 해당 안내서를 완성하였습니다.
