소개
This guide is useful when encountering broken or stuck keys.
필요한 것
First, on the back of the phone find the silver button on the top left corner of the phone.
Simultaneously push down the button and slide the back plate down to reveal the battery.
Push the metal slider towards the top of the phone until it clicks out of the original position.
Gently slide out and remove the SIM card.
Grip the antenna and twist it counterclockwise to loosen it.
When it has been loosened all the way, pull gently to remove the antenna piece.
Using the push pin, gently pry the top two screws of the cover off.
The cover in the upper left of the back plate does not need to be removed.
With the phone flipped open, peel the keypad back to remove it from the casing, starting from the bottom.
다른 한 분이 해당 안내서를 완성하였습니다.
