주요 콘텐츠로 건너뛰기
Motorola V557 Rear Casing Replacement
필요한 것
  1. Motorola V557 Rear Casing Replacement, Battery: 1 단계, 이미지 1/3 Motorola V557 Rear Casing Replacement, Battery: 1 단계, 이미지 2/3 Motorola V557 Rear Casing Replacement, Battery: 1 단계, 이미지 3/3
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
  2. Motorola V557 Rear Casing Replacement: 2 단계, 이미지 1/2 Motorola V557 Rear Casing Replacement: 2 단계, 이미지 2/2
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
  3. Motorola V557 Rear Casing Replacement, SIM Card: 3 단계, 이미지 1/3 Motorola V557 Rear Casing Replacement, SIM Card: 3 단계, 이미지 2/3 Motorola V557 Rear Casing Replacement, SIM Card: 3 단계, 이미지 3/3
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
  4. Motorola V557 Rear Casing Replacement, Antenna: 4 단계, 이미지 1/2 Motorola V557 Rear Casing Replacement, Antenna: 4 단계, 이미지 2/2
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
  5. Motorola V557 Rear Casing Replacement, Rear Casing: 5 단계, 이미지 1/3 Motorola V557 Rear Casing Replacement, Rear Casing: 5 단계, 이미지 2/3 Motorola V557 Rear Casing Replacement, Rear Casing: 5 단계, 이미지 3/3
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
  6. Motorola V557 Rear Casing Replacement: 6 단계, 이미지 1/3 Motorola V557 Rear Casing Replacement: 6 단계, 이미지 2/3 Motorola V557 Rear Casing Replacement: 6 단계, 이미지 3/3
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
  7. Motorola V557 Rear Casing Replacement: 7 단계, 이미지 1/3 Motorola V557 Rear Casing Replacement: 7 단계, 이미지 2/3 Motorola V557 Rear Casing Replacement: 7 단계, 이미지 3/3
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
결론
Alex Georges
회원 가입일: 10/02/10
40 평판
안내서 4개 작성하였습니다
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G50
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,346
