주요 콘텐츠로 건너뛰기
Motorola V60c Keypad and Keypad Logic Board Replacement
필요한 것
  1. Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola V60c Keypad and Keypad Logic Board Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Keypad and Keypad Logic Board Replacement: 2 단계, 이미지 2개 중 1개 Motorola V60c Keypad and Keypad Logic Board Replacement: 2 단계, 이미지 2개 중 2개
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Keypad and Keypad Logic Board Replacement, Keypad and Keypad Logic Board: 3 단계, 이미지 1개 중 1개
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Keypad and Keypad Logic Board Replacement: 4 단계, 이미지 2개 중 1개 Motorola V60c Keypad and Keypad Logic Board Replacement: 4 단계, 이미지 2개 중 2개
    • Use plastic opening tool to pry up back cover from two side clips.
    • NOTE: Sticker might be attached to rest of phone.
  5. Motorola V60c Keypad and Keypad Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the back cover.
  6. Motorola V60c Keypad and Keypad Logic Board Replacement: 6 단계, 이미지 2개 중 1개 Motorola V60c Keypad and Keypad Logic Board Replacement: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board.
    • NOTE: Rubber side buttons are not secure and might detach from the main logic board during removal.
  7. Motorola V60c Keypad and Keypad Logic Board Replacement: 7 단계, 이미지 2개 중 1개 Motorola V60c Keypad and Keypad Logic Board Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the keypad logic board.
    • NOTE: Plastic spacer is not secured to keypad logic board and might detach during removal.
  8. Motorola V60c Keypad and Keypad Logic Board Replacement: 8 단계, 이미지 3개 중 1개 Motorola V60c Keypad and Keypad Logic Board Replacement: 8 단계, 이미지 3개 중 2개 Motorola V60c Keypad and Keypad Logic Board Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the keypad.
결론
작성자
6다른 기여자 명과 함께
Ryan Kuroiwa
회원 가입일: 04/10/10
1 평판
안내서 5개를 작성함
Cal Poly, Team 25-86, Amido Spring 2010 Cal Poly, Team 25-86, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G86
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 2,210
