주요 콘텐츠로 건너뛰기
Motorola V60c Motherboard Replacement
필요한 것
  1. Motorola V60c Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Motorola V60c Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Depress the silver button.
    • Pull from top of phone to lift the cover.
  2. Motorola V60c Motherboard Replacement: 2 단계, 이미지 1/2 Motorola V60c Motherboard Replacement: 2 단계, 이미지 2/2
    • Hold battery from both sides at the bottom.
    • Push upwards and gently lift to remove.
  3. Motorola V60c Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove 4 screws from corners using T-6 screwdriver.
    • NOTE: Bottom two screws are gold.
    • NOTE: Make sure screws return to correct place when reassembling.
  4. Motorola V60c Motherboard Replacement: 4 단계, 이미지 1/2 Motorola V60c Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pry up back cover from the two side clips.
    • NOTE: sticker might be attached to rest of phone.
  5. Motorola V60c Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the back cover.
  6. Motorola V60c Motherboard Replacement: 6 단계, 이미지 1/2 Motorola V60c Motherboard Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to gently remove the orange ribbon cable.
    • Lift up the main logic board to remove.
결론
Ryan Kuroiwa
회원 가입일: 04/10/10
1 평판
안내서 5개 작성하였습니다
Cal Poly, Team 25-86, Amido Spring 2010 Cal Poly, Team 25-86, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G86
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 2,352
