주요 콘텐츠로 건너뛰기
Motorola V60i Back Plate Replacement
필요한 것
  1. Motorola V60i Back Plate Replacement, Battery: 1 단계, 이미지 1/2 Motorola V60i Back Plate Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Back Plate Replacement: 2 단계, 이미지 1/2 Motorola V60i Back Plate Replacement: 2 단계, 이미지 2/2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Back Plate Replacement, Back Plate: 3 단계, 이미지 1/1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Back Plate Replacement: 4 단계, 이미지 1/2 Motorola V60i Back Plate Replacement: 4 단계, 이미지 2/2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Back Plate Replacement: 5 단계, 이미지 1/1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
결론
Elizabeth OBrien
회원 가입일: 04/26/10
43 평판
안내서 7개 작성하였습니다
Cal Poly, Team 30-40, Garner Spring 2010 Cal Poly, Team 30-40, Garner Spring 2010 회원
CPSU-GARNER-S10S30G40
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 3,525
