주요 콘텐츠로 건너뛰기
Motorola V60s Button Key Pad Replacement
필요한 것
  1. Motorola V60s Button Key Pad Replacement, Battery: 1 단계, 이미지 1/3 Motorola V60s Button Key Pad Replacement, Battery: 1 단계, 이미지 2/3 Motorola V60s Button Key Pad Replacement, Battery: 1 단계, 이미지 3/3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Button Key Pad Replacement: 2 단계, 이미지 1/2 Motorola V60s Button Key Pad Replacement: 2 단계, 이미지 2/2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Button Key Pad Replacement, Logic Board: 3 단계, 이미지 1/2 Motorola V60s Button Key Pad Replacement, Logic Board: 3 단계, 이미지 2/2
    • Unscrew four corner screws with T6 screwdriver.
    • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. Motorola V60s Button Key Pad Replacement: 4 단계, 이미지 1/3 Motorola V60s Button Key Pad Replacement: 4 단계, 이미지 2/3 Motorola V60s Button Key Pad Replacement: 4 단계, 이미지 3/3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  5. Motorola V60s Button Key Pad Replacement: 5 단계, 이미지 1/3 Motorola V60s Button Key Pad Replacement: 5 단계, 이미지 2/3 Motorola V60s Button Key Pad Replacement: 5 단계, 이미지 3/3
    • Starting from left side of phone, remove side buttons and place aside.
    • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  6. Motorola V60s Button Key Pad Replacement: 6 단계, 이미지 1/3 Motorola V60s Button Key Pad Replacement: 6 단계, 이미지 2/3 Motorola V60s Button Key Pad Replacement: 6 단계, 이미지 3/3
    • Gently remove orange ribbon cable by prying up with spudger.
  7. Motorola V60s Button Key Pad Replacement: 7 단계, 이미지 1/2 Motorola V60s Button Key Pad Replacement: 7 단계, 이미지 2/2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Note: Orange ribbon cable is fragile and can be broken.
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: 8 단계, 이미지 1/2 Motorola V60s Button Key Pad Replacement, Button Key Board: 8 단계, 이미지 2/2
    • Insert spudger under button board and gently lift, set aside.
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: 9 단계, 이미지 1/2 Motorola V60s Button Key Pad Replacement, Button Key Pad: 9 단계, 이미지 2/2
    • Life button keypad with spudger and set aside.
결론
Eric Freeman
회원 가입일: 01/26/10
10 평판
안내서 7개 작성하였습니다
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 회원
CPSU-REGAN-W10S8G48
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,012
