소개
This guide shows how to replace the logic board.
  1. Remove battery cover by pushing down release lever at top of phone while prying off cover. Set cover aside. Set cover aside.
    • Remove battery cover by pushing down release lever at top of phone while prying off cover.
    • Set cover aside.
  2. Remove battery by grabbing it near the bottom and lifting out. Remove battery by grabbing it near the bottom and lifting out.
    • Remove battery by grabbing it near the bottom and lifting out.
  3. Unscrew four corner screws with T6 screwdriver. Note: The two top screws are short and silver.  The two bottom screws are black and long.
    • Unscrew four corner screws with T6 screwdriver.
      • Note: The two top screws are short and silver. The two bottom screws are black and long.
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift. Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift. Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
  6. Starting from left side of phone, remove side buttons and place aside. Note: There should be three buttons. One on each side, and the top. Return phone to starting orientation when done.
    • Starting from left side of phone, remove side buttons and place aside.
      • Note: There should be three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
  7. Gently remove orange ribbon cable by prying up with spudger. Gently remove orange ribbon cable by prying up with spudger. Gently remove orange ribbon cable by prying up with spudger.
    • Gently remove orange ribbon cable by prying up with spudger.
  8. Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting. Note: Orange ribbon cable is fragile and can be broken.
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
      • Note: Orange ribbon cable is fragile and can be broken.
결론
Eric Freeman
회원 가입일: 2010년 01월 26일
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 회원
CPSU-REGAN-W10S8G48
4 회원들
안내서 13개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 1
전체 시간: 1,757
