주요 콘텐츠로 건너뛰기
Motorola V60s Speakers Replacement
필요한 것
  1. Motorola V60s Speakers Replacement, Battery: 1 단계, 이미지 1/3 Motorola V60s Speakers Replacement, Battery: 1 단계, 이미지 2/3 Motorola V60s Speakers Replacement, Battery: 1 단계, 이미지 3/3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
  2. Motorola V60s Speakers Replacement: 2 단계, 이미지 1/2 Motorola V60s Speakers Replacement: 2 단계, 이미지 2/2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
  3. Motorola V60s Speakers Replacement, Speakers: 3 단계, 이미지 1/2 Motorola V60s Speakers Replacement, Speakers: 3 단계, 이미지 2/2
    • Remove the four screws using a T6 Torx screwdriver.
    • Top screws are silver and short while bottom screws are black and longer.
  4. Motorola V60s Speakers Replacement: 4 단계, 이미지 1/2 Motorola V60s Speakers Replacement: 4 단계, 이미지 2/2
    • Insert an iFixit opening tool into phone in between back panel and body of phone.
    • Carefully pry up until back panel comes off, then remove with hands and set aside.
  5. Motorola V60s Speakers Replacement: 5 단계, 이미지 1/1
    • Carefully insert an iFixit opening tool between the speaker and phone chassis. Slowly pry until speakers come out.
    • Be careful on this step; it may take some time.
결론
Eric Freeman
회원 가입일: 01/26/10
10 평판
안내서 7개 작성하였습니다
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 회원
CPSU-REGAN-W10S8G48
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,552
