주요 콘텐츠로 건너뛰기
Motorola V710 Camera Replacement
필요한 것
  1. Motorola V710 Camera Replacement, Screen: 1 단계, 이미지 1/3 Motorola V710 Camera Replacement, Screen: 1 단계, 이미지 2/3 Motorola V710 Camera Replacement, Screen: 1 단계, 이미지 3/3
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
  2. Motorola V710 Camera Replacement: 2 단계, 이미지 1/2 Motorola V710 Camera Replacement: 2 단계, 이미지 2/2
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
  3. Motorola V710 Camera Replacement: 3 단계, 이미지 1/2 Motorola V710 Camera Replacement: 3 단계, 이미지 2/2
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
  4. Motorola V710 Camera Replacement: 4 단계, 이미지 1/2 Motorola V710 Camera Replacement: 4 단계, 이미지 2/2
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
  5. Motorola V710 Camera Replacement: 5 단계, 이미지 1/2 Motorola V710 Camera Replacement: 5 단계, 이미지 2/2
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
  6. Motorola V710 Camera Replacement: 6 단계, 이미지 1/2 Motorola V710 Camera Replacement: 6 단계, 이미지 2/2
    • Use the spudger to remove the screen.
  7. Motorola V710 Camera Replacement, Camera: 7 단계, 이미지 1/3 Motorola V710 Camera Replacement, Camera: 7 단계, 이미지 2/3 Motorola V710 Camera Replacement, Camera: 7 단계, 이미지 3/3
    • Use the spudger to remove the camera module.
    • Note: The camera has an adhesive holding it in place, so a slight force is necessary to remove it.
결론
Karl Sanders
회원 가입일: 01/26/10
8 평판
안내서 7개 작성하였습니다
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 회원
CPSU-REGAN-W10S8G49
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 1,574
