주요 콘텐츠로 건너뛰기
Motorola V710 Keyboard Replacement
필요한 것
  1. Motorola V710 Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Motorola V710 Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Motorola V710 Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Press down on the back button while pulling away from the body of the phone to release the back cover.
  2. Motorola V710 Keyboard Replacement: 2 단계, 이미지 1/3 Motorola V710 Keyboard Replacement: 2 단계, 이미지 2/3 Motorola V710 Keyboard Replacement: 2 단계, 이미지 3/3
    • Remove the battery from the phone by gently pulling upward on the battery with your fingers.
  3. Motorola V710 Keyboard Replacement, Keypad: 3 단계, 이미지 1/1
    • Unscrew the antenna with a clockwise motion and pull to remove the antenna.
  4. Motorola V710 Keyboard Replacement: 4 단계, 이미지 1/2 Motorola V710 Keyboard Replacement: 4 단계, 이미지 2/2
    • Remove the screws under the antenna and to the right side of the phone with the T6 Torx screwdriver.
  5. Motorola V710 Keyboard Replacement: 5 단계, 이미지 1/2 Motorola V710 Keyboard Replacement: 5 단계, 이미지 2/2
    • Use the spudger to remove the bottom plate.
  6. Motorola V710 Keyboard Replacement: 6 단계, 이미지 1/2 Motorola V710 Keyboard Replacement: 6 단계, 이미지 2/2
    • Unscrew the bottom two screws with the T6 screwdriver.
  7. Motorola V710 Keyboard Replacement: 7 단계, 이미지 1/2 Motorola V710 Keyboard Replacement: 7 단계, 이미지 2/2
    • Use the spudger to remove the keyboard plate.
  8. Motorola V710 Keyboard Replacement: 8 단계, 이미지 1/1
    • Use your fingers to push out the keyboard.
결승점
Karl Sanders
회원 가입일: 01/26/10
8 평판
안내서 7개 작성하였습니다
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 회원
CPSU-REGAN-W10S8G49
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 1,971
