부품
부품은 필요하지 않습니다.
  1. Turn off the phone.
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Insert the new battery.
    • Insert the new battery.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. Four 5 mm screws are visible (circled in red).
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  5. Insert the plastic opening tool between the front and back panels of the lower half of the device. Slide the tool around the entire frame of the device until it has loosened. Remove the back of the device.
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  6. Gently twist the antenna in a counter-clockwise direction to unscrew it.
    • Gently twist the antenna in a counter-clockwise direction to unscrew it.
  7. Pull the antenna out through the hole in the top of the frame and set it aside. Pull the antenna out through the hole in the top of the frame and set it aside.
    • Pull the antenna out through the hole in the top of the frame and set it aside.
  8. Using a plastic opening tool, lift and remove the antenna casing. Using a plastic opening tool, lift and remove the antenna casing. Using a plastic opening tool, lift and remove the antenna casing.
    • Using a plastic opening tool, lift and remove the antenna casing.
결론
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Justin Scott
회원 가입일: 2014년 03월 26일
501 평판
안내서 5개 작성하였습니다
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014 회원
CLEM-BENSON-S14S6G3
3 회원들
안내서 18개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 124
