주요 콘텐츠로 건너뛰기
Motorola W315 Circuit Board Replacement
필요한 것
  1. Motorola W315 Circuit Board Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the phone.
    • Turn the device over.
    • Remove the battery cover.
    • Insert thumb in the gap between the button and the battery and pry the battery upwards.
    • Pull the battery out of the phone.
  2. Motorola W315 Circuit Board Replacement: 3 단계, 이미지 1/1
    • Insert the new battery.
  3. Motorola W315 Circuit Board Replacement, Rear Case: 4 단계, 이미지 1/1
    • Four 5 mm screws are visible (circled in red).
    • Using the T6 tool, remove all four 5mm screws and set them aside.
  4. Motorola W315 Circuit Board Replacement: 5 단계, 이미지 1/3 Motorola W315 Circuit Board Replacement: 5 단계, 이미지 2/3 Motorola W315 Circuit Board Replacement: 5 단계, 이미지 3/3
    • Insert the plastic opening tool between the front and back panels of the lower half of the device.
    • Slide the tool around the entire frame of the device until it has loosened.
    • Remove the back of the device.
  5. Motorola W315 Circuit Board Replacement, Circuit Board: 6 단계, 이미지 1/3 Motorola W315 Circuit Board Replacement, Circuit Board: 6 단계, 이미지 2/3 Motorola W315 Circuit Board Replacement, Circuit Board: 6 단계, 이미지 3/3
    • Using the plastic opening tool, gently lift the circuit board off of the four gray pegs that it rests upon.
  6. Motorola W315 Circuit Board Replacement: 7 단계, 이미지 1/3 Motorola W315 Circuit Board Replacement: 7 단계, 이미지 2/3 Motorola W315 Circuit Board Replacement: 7 단계, 이미지 3/3
    • Use the plastic opening tool to remove the chip connected by magnetic strip to the screen.
    • Remove circuit board.
결론
Information on recycling/disposing of your electronic waste is located under Additional Information on the device page.
Jacob Gray
회원 가입일: 03/26/14
399 평판
안내서 4개 작성하였습니다
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014 회원
CLEM-BENSON-S14S6G3
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 185
