주요 콘텐츠로 건너뛰기
Motorola W315 Screen Replacement
필요한 것
  1. Motorola W315 Screen Replacement, Display Cover: 1 단계, 이미지 1/3 Motorola W315 Screen Replacement, Display Cover: 1 단계, 이미지 2/3 Motorola W315 Screen Replacement, Display Cover: 1 단계, 이미지 3/3
    • Insert the spudger between the silver body of the phone and the black "Verizon" display sticker.
    • Work the spudger around the extremity of the sticker.
    • Remove display sticker.
    • Be aware that if the display sticker comes back in contact with the phone it will adhere back to the phone.
  2. Motorola W315 Screen Replacement, Screen: 2 단계, 이미지 1/1
    • Using the T6 tool, remove the four 5mm screws on the face of the display (circled in red).Before replacing the screen, the four screws beneath the display must already be removed.
  3. Motorola W315 Screen Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Insert the tweezers between the front and back panels of the top half of the device. Make as large a gap as possible using the tweezers.
  4. Motorola W315 Screen Replacement: 4 단계, 이미지 1/3 Motorola W315 Screen Replacement: 4 단계, 이미지 2/3 Motorola W315 Screen Replacement: 4 단계, 이미지 3/3
    • Using the Pry Bar, move around the entire edge of the the device until the two panels separate from each other.
    • Grab the plastic casing and remove
  5. Motorola W315 Screen Replacement: 5 단계, 이미지 1/3 Motorola W315 Screen Replacement: 5 단계, 이미지 2/3 Motorola W315 Screen Replacement: 5 단계, 이미지 3/3
    • Use the pry bar to lift the metal cover from the screen housing.
  6. Motorola W315 Screen Replacement: 6 단계, 이미지 1/2 Motorola W315 Screen Replacement: 6 단계, 이미지 2/2
    • Pry the chip connected by magnetic strip from the back of the screen.
    • Remove display circuit board from the body of the phone.
  7. Motorola W315 Screen Replacement: 7 단계, 이미지 1/2 Motorola W315 Screen Replacement: 7 단계, 이미지 2/2
    • Remove the screen from the front panel of the device.
결론
Justin Scott
회원 가입일: 03/26/14
501 평판
안내서 5개 작성하였습니다
Clemson, Team 6-3, Benson Spring 2014 Clemson, Team 6-3, Benson Spring 2014 회원
CLEM-BENSON-S14S6G3
3 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 187
