소개
Is the plastic casing cracked or severely scratched? Replace it.
  1. Using your finger, press down on the clip holding the back cover on.
    • Using your finger, press down on the clip holding the back cover on.
  2. Using the spudger or your finger, gently pull the battery out from the top.
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  5. Remove the four Torx-6 screws from underneath the rubber pieces.
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  6. Close the phone before proceeding. Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  7. If the casing has not popped off of the body, remove it carefully from the the phone.
    • If the casing has not popped off of the body, remove it carefully from the the phone.
결론
Austin Hobbs
회원 가입일: 2010년 01월 21일
30 평판
안내서 3개 작성하였습니다
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 회원
CPSU-REGAN-W10S8G50
3 회원들
안내서 14개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 1,830
