소개
Have a faulty logic board? Replace it
부품
부품은 필요하지 않습니다.
  1. Using your finger, press down on the clip holding the back cover on.
    • Using your finger, press down on the clip holding the back cover on.
  2. Using the spudger or your finger, gently pull the battery out from the top.
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Hold the phone as shown in the photo.
    • Hold the phone as shown in the photo.
  4. Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center. This might require a little persistence due how the beveled plastic rests on the phone body.
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
  5. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  6. Remove the two Torx-6 screws under the removed plastic.
    • Remove the two Torx-6 screws under the removed plastic.
  7. Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
  8. Hold the phone with the keys facing down and the mini USB charging port visible. Open the rubber flap covering the charging port. Insert the flat end of the spudger just above the charging port.
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
  9. The casing can be easily removed exposing the bottom logic board.
    • The casing can be easily removed exposing the bottom logic board.
  10. Use spudger to gently separate the ribbon cable from the logic board. Use spudger to gently separate the ribbon cable from the logic board.
    • Use spudger to gently separate the ribbon cable from the logic board.
  11. Place the sharp end of the spudger in the hole at the bottom of the logic board. Gently remove the logic board from the phone casing.
    • Place the sharp end of the spudger in the hole at the bottom of the logic board.
    • Gently remove the logic board from the phone casing.
    • Make sure not to damage any other components of the logic board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Javier Mendez
회원 가입일: 2010년 01월 21일
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 회원
CPSU-REGAN-W10S8G50
3 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 5
전체 시간: 3,059
