주요 콘텐츠로 건너뛰기
Motorola W385 Logic Board Replacement
필요한 것
  1. Motorola W385 Logic Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Logic Board Replacement: 2 단계, 이미지 1개 중 1개
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Logic Board Replacement, Bottom Casing: 3 단계, 이미지 1개 중 1개
    • Hold the phone as shown in the photo.
  4. Motorola W385 Logic Board Replacement: 4 단계, 이미지 2개 중 1개 Motorola W385 Logic Board Replacement: 4 단계, 이미지 2개 중 2개
    • Using the flat side of the spudger and a little pressure, insert it under the bottom plastic piece at about center.
    • This might require a little persistence due how the beveled plastic rests on the phone body.
    • After the spudger is under the plastic piece, move counter clockwise using a gentle twisting motion until the piece is free from the phone body.
  5. Motorola W385 Logic Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two Torx-6 screws under the removed plastic.
  6. Motorola W385 Logic Board Replacement: 6 단계, 이미지 1개 중 1개
    • Keeping the phone open, turn it over allowing the battery compartment to be visible.
    • Remove the four Torx-6 screws from the back plastic.
  7. Motorola W385 Logic Board Replacement: 7 단계, 이미지 3개 중 1개 Motorola W385 Logic Board Replacement: 7 단계, 이미지 3개 중 2개 Motorola W385 Logic Board Replacement: 7 단계, 이미지 3개 중 3개
    • Hold the phone with the keys facing down and the mini USB charging port visible.
    • Open the rubber flap covering the charging port.
    • Insert the flat end of the spudger just above the charging port.
    • Using the same gentle twisting motion, work around the bottom of the phone and up the opposite side. The back casing should separate from the body of the phone.
    • When working on the thinner pieces of the plastic casing, use caution insuring the plastic does not crack.
  8. Motorola W385 Logic Board Replacement: 8 단계, 이미지 1개 중 1개
    • The casing can be easily removed exposing the bottom logic board.
  9. Motorola W385 Logic Board Replacement, Main Logic Board: 9 단계, 이미지 2개 중 1개 Motorola W385 Logic Board Replacement, Main Logic Board: 9 단계, 이미지 2개 중 2개
    • Use spudger to gently separate the ribbon cable from the logic board.
  10. Motorola W385 Logic Board Replacement: 10 단계, 이미지 2개 중 1개 Motorola W385 Logic Board Replacement: 10 단계, 이미지 2개 중 2개
    • Place the sharp end of the spudger in the hole at the bottom of the logic board.
    • Gently remove the logic board from the phone casing.
    • Make sure not to damage any other components of the logic board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Javier Mendez
회원 가입일: 01/21/10
13 평판
안내서 2개를 작성함
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 회원
CPSU-REGAN-W10S8G50
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 3,342
