주요 콘텐츠로 건너뛰기
Motorola W385 Top Logic Board Replacement
필요한 것
  1. Motorola W385 Top Logic Board Replacement, Battery: 1 단계, 이미지 1/1
    • Using your finger, press down on the clip holding the back cover on.
  2. Motorola W385 Top Logic Board Replacement: 2 단계, 이미지 1/1
    • Using the spudger or your finger, gently pull the battery out from the top.
  3. Motorola W385 Top Logic Board Replacement, Front Casing: 3 단계, 이미지 1/1
    • Remove the four rubber pieces from the face of the phone using the sharp end of the spudger.
    • The rubber pieces are held in with a mild adhesive.
  4. Motorola W385 Top Logic Board Replacement: 4 단계, 이미지 1/1
    • Remove the four Torx-6 screws from underneath the rubber pieces.
  5. Motorola W385 Top Logic Board Replacement: 5 단계, 이미지 1/2 Motorola W385 Top Logic Board Replacement: 5 단계, 이미지 2/2
    • Close the phone before proceeding.
    • Using the flat end of the spudger, insert it under the plastic at the top left of the phone.
    • Gently, although a small amount of force is required, use a twisting motion to pull the plastic casing away from the body of the phone.
    • Continue to move around the phone counter clockwise until the casing is separated from the body.
    • It is not unusual for it to pop off before making it back to the starting point.
  6. Motorola W385 Top Logic Board Replacement: 6 단계, 이미지 1/1
    • If the casing has not popped off of the body, remove it carefully from the the phone.
  7. Motorola W385 Top Logic Board Replacement, Top Logic Board: 7 단계, 이미지 1/1
    • After completing Steps 3-6 in the casing repair guide, your phone should look like this.
  8. Motorola W385 Top Logic Board Replacement: 8 단계, 이미지 1/3 Motorola W385 Top Logic Board Replacement: 8 단계, 이미지 2/3 Motorola W385 Top Logic Board Replacement: 8 단계, 이미지 3/3
    • Use the spudger to unhinge the four clips around the metal casing of the top logic board.
    • Gently take off the metal casing of the logic board.
  9. Motorola W385 Top Logic Board Replacement: 9 단계, 이미지 1/3 Motorola W385 Top Logic Board Replacement: 9 단계, 이미지 2/3 Motorola W385 Top Logic Board Replacement: 9 단계, 이미지 3/3
    • Use spudger to gently disconnect the ribbon cable from phone.
    • Gently remove Logic Board making sure not to damage any other components.
결론
Javier Mendez
회원 가입일: 01/21/10
13 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-50, Regan Winter 2010 Cal Poly, Team 8-50, Regan Winter 2010 회원
CPSU-REGAN-W10S8G50
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 2,520
