주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. Open the phone so that the keypad and screen are facing up.
    • Open the phone so that the keypad and screen are facing up.
  2. Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
  3. Use the Torx T5 screw driver head to remove the four 5.4 mm screws from the upper inner face.
    • Use the Torx T5 screw driver head to remove the four 5.4 mm screws from the upper inner face.
  4. Once the screws and upper casing have been removed, locate where the camera attaches to the upper circuit board and detach it using a pair of tweezers.
    • Once the screws and upper casing have been removed, locate where the camera attaches to the upper circuit board and detach it using a pair of tweezers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Will Edwards
회원 가입일: 2012년 10월 22일
61 평판
안내서 9개 작성하였습니다
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 회원
CLEM-BENSON-F12S14G1
4 회원들
안내서 23개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 333
