부품
부품은 필요하지 않습니다.
  1. Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face. Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  2. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone. Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
    • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  3. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Pull the flex cable connection away from the top of the phone. Pull the flex cable connection away from the top of the phone.
    • Pull the flex cable connection away from the top of the phone.
  5. Pull the camera connection away from the top of the phone. Pull the camera connection away from the top of the phone.
    • Pull the camera connection away from the top of the phone.
  6. Pull the upper metal frame away from the phone. Pull the upper metal frame away from the phone. Pull the upper metal frame away from the phone.
    • Pull the upper metal frame away from the phone.
  7. Hold the outer phone casing and pull the LCD screen out. Hold the outer phone casing and pull the LCD screen out. Hold the outer phone casing and pull the LCD screen out.
    • Hold the outer phone casing and pull the LCD screen out.
결론
Will Edwards
회원 가입일: 2012년 10월 22일
61 평판
안내서 9개 작성하였습니다
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 회원
CLEM-BENSON-F12S14G1
4 회원들
안내서 23개 작성하였습니다
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - 답글
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 418
