주요 콘텐츠로 건너뛰기
Motorola W490 LCD Screen Replacement
필요한 것
  1. Motorola W490 LCD Screen Replacement, Upper Metal Frame: 1 단계, 이미지 1/2 Motorola W490 LCD Screen Replacement, Upper Metal Frame: 1 단계, 이미지 2/2
    • Use the blue plastic opening tool to pry off all four of the rubber stickers from the upper inside face.
    • Use the Torx T5 screwdriver to remove the four 5.4 mm screws from the upper inner face.
  2. Motorola W490 LCD Screen Replacement: 2 단계, 이미지 1/3 Motorola W490 LCD Screen Replacement: 2 단계, 이미지 2/3 Motorola W490 LCD Screen Replacement: 2 단계, 이미지 3/3
    • Use a flathead screwdriver or plastic opening tools to help pry the top cover away from the phone.
  3. Motorola W490 LCD Screen Replacement: 3 단계, 이미지 1/2 Motorola W490 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Pull the flex cable connection away from the top of the phone.
  4. Motorola W490 LCD Screen Replacement: 4 단계, 이미지 1/2 Motorola W490 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Pull the camera connection away from the top of the phone.
  5. Motorola W490 LCD Screen Replacement: 5 단계, 이미지 1/3 Motorola W490 LCD Screen Replacement: 5 단계, 이미지 2/3 Motorola W490 LCD Screen Replacement: 5 단계, 이미지 3/3
    • Pull the upper metal frame away from the phone.
  6. Motorola W490 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 1/3 Motorola W490 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 2/3 Motorola W490 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3/3
    • Hold the outer phone casing and pull the LCD screen out.
결론
Will Edwards
회원 가입일: 10/22/12
61 평판
안내서 9개 작성하였습니다
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 회원
CLEM-BENSON-F12S14G1
4 회원들
안내서 23개 작성하였습니다
댓글 한 개
It's fantastic when someone takes the time to compile photos and directions as good as these. Not only does it make the repairs possible, but it makes them so much easier. Thanks!
Bill Dominic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 521
