주요 콘텐츠로 건너뛰기
Motorola W490 SIM Card Replacement
필요한 것
  1. Motorola W490 SIM Card Replacement, Phone Casing: 1 단계, 이미지 1/2 Motorola W490 SIM Card Replacement, Phone Casing: 1 단계, 이미지 2/2
    • Pick up the cell phone with the back facing towards you.
    • Push down on the silver tab located at the top center of the back of the Motorola W490 cellphone.
    • While pushing down on the silver tab, slide the back cover towards the silver tab. Remove the back cover.
  2. Motorola W490 SIM Card Replacement, Battery: 2 단계, 이미지 1/2 Motorola W490 SIM Card Replacement, Battery: 2 단계, 이미지 2/2
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Set the battery aside.
  3. Motorola W490 SIM Card Replacement, SIM Card: 3 단계, 이미지 1/3 Motorola W490 SIM Card Replacement, SIM Card: 3 단계, 이미지 2/3 Motorola W490 SIM Card Replacement, SIM Card: 3 단계, 이미지 3/3
    • Use a plastic opening tool to make a gap between the SIM card and the phone.
    • Use your thumb and index finger to pull the SIM card from the phone.
결론
Will Edwards
회원 가입일: 10/22/12
61 평판
안내서 9개 작성하였습니다
Clemson, Team 14-1, Benson Fall 2012 Clemson, Team 14-1, Benson Fall 2012 회원
CLEM-BENSON-F12S14G1
4 회원들
안내서 23개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 802
