주요 콘텐츠로 건너뛰기
Motorola XOOM 2 Media Edition Battery Replacement
필요한 것
  1. Motorola XOOM 2 Media Edition Battery Replacement, Battery: 1 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Power off your tablet before beginning disassembly.
    • Remove six 2.74mm Torx #3 screws from the back panel of the device with a Torx T3 screwdriver.
  2. Motorola XOOM 2 Media Edition Battery Replacement: 2 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Battery Replacement: 2 단계, 이미지 2/2
    • There is adhesive attached to the underside of the back panel. Gradually lift panel to avoid bending it out of shape.
    • Pry off the back panel with a plastic opening tool.
  3. Motorola XOOM 2 Media Edition Battery Replacement: 3 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Battery Replacement: 3 단계, 이미지 2/2
    • These screws are tight and prone to becoming stripped.
    • The battery cables are likely to snap when removing the screws.
    • Remove two 2.38mm Torx #5 screws from battery cables with Torx T5 screwdriver.
  4. Motorola XOOM 2 Media Edition Battery Replacement: 4 단계, 이미지 1/3 Motorola XOOM 2 Media Edition Battery Replacement: 4 단계, 이미지 2/3 Motorola XOOM 2 Media Edition Battery Replacement: 4 단계, 이미지 3/3
    • Pull up the battery cables and battery chip with tweezers.
  5. Motorola XOOM 2 Media Edition Battery Replacement: 5 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Battery Replacement: 5 단계, 이미지 2/2
    • Pry the battery out of the device with the plastic opening tool.
    • Some force is needed to lift the battery up because of the adhesive attached to the backside of the battery.
결론
Taylor
회원 가입일: 09/28/16
197 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 1,054
