주요 콘텐츠로 건너뛰기
Motorola XOOM 2 Media Edition Speakers Replacement
필요한 것
  1. Motorola XOOM 2 Media Edition Speakers Replacement, Motorola XOOM 2 Media Edition Disassembly: 1 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Speakers Replacement, Motorola XOOM 2 Media Edition Disassembly: 1 단계, 이미지 2/2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Speakers Replacement: 2 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Speakers Replacement: 2 단계, 이미지 2/2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Speakers Replacement: 3 단계, 이미지 1/3 Motorola XOOM 2 Media Edition Speakers Replacement: 3 단계, 이미지 2/3 Motorola XOOM 2 Media Edition Speakers Replacement: 3 단계, 이미지 3/3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Speakers Replacement, Speakers: 4 단계, 이미지 1/3 Motorola XOOM 2 Media Edition Speakers Replacement, Speakers: 4 단계, 이미지 2/3 Motorola XOOM 2 Media Edition Speakers Replacement, Speakers: 4 단계, 이미지 3/3
    • Using the tweezers, gently pull up the connector of each of the speakers.
  5. Motorola XOOM 2 Media Edition Speakers Replacement: 5 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Speakers Replacement: 5 단계, 이미지 2/2
    • Once the connector is removed, use the tweezers to pull up the speaker from its plastic socket on both of the speakers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jillian Cain
회원 가입일: 09/28/16
319 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 168
