주요 콘텐츠로 건너뛰기
Motorola XOOM 2 Media Edition Touch Screen Replacement
필요한 것
  1. Motorola XOOM 2 Media Edition Touch Screen Replacement, Motorola XOOM 2 Media Edition Disassembly: 1 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Touch Screen Replacement, Motorola XOOM 2 Media Edition Disassembly: 1 단계, 이미지 2/2
    • Power off the device before beginning disassembly.
    • Remove six 2.7mm Torx #3 screws.
  2. Motorola XOOM 2 Media Edition Touch Screen Replacement: 2 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Touch Screen Replacement: 2 단계, 이미지 2/2
    • There is adhesive attached to the underside of the back panel. Gradually lift the panel to avoid bending it out of shape.
    • Pry off the back panel using a plastic opening tool.
    • Using a plastic opening tool, slide the tool gently around the back cover to lift the cover off.
  3. Motorola XOOM 2 Media Edition Touch Screen Replacement: 3 단계, 이미지 1/3 Motorola XOOM 2 Media Edition Touch Screen Replacement: 3 단계, 이미지 2/3 Motorola XOOM 2 Media Edition Touch Screen Replacement: 3 단계, 이미지 3/3
    • Pry off the black cover gradually using a plastic opening tool.
  4. Motorola XOOM 2 Media Edition Touch Screen Replacement, Touch Screen: 4 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Touch Screen Replacement, Touch Screen: 4 단계, 이미지 2/2
    • Remove thirteen 2.55mm Torx #4 screws with Torx T4 screwdriver.
  5. Motorola XOOM 2 Media Edition Touch Screen Replacement: 5 단계, 이미지 1/1
    • Use tweezers to pull up the white rubber cover.
  6. Motorola XOOM 2 Media Edition Touch Screen Replacement: 6 단계, 이미지 1/3 Motorola XOOM 2 Media Edition Touch Screen Replacement: 6 단계, 이미지 2/3 Motorola XOOM 2 Media Edition Touch Screen Replacement: 6 단계, 이미지 3/3
    • Use the tweezers to pull up the small chip from its receiver.
    • Use the tweezers to pull up the larger chip from its receiver.
    • There is adhesive attached to the back of the larger chip on the touchscreen controller strip.
    • Use the tweezers to pull up one end of the small piece of tape that is holding the touchscreen controller.
  7. Motorola XOOM 2 Media Edition Touch Screen Replacement: 7 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Touch Screen Replacement: 7 단계, 이미지 2/2
    • Use the tweezers to pull up and release the thin handle that is attached to the LCD connector.
    • Use the tweezers to pull out the LCD connector from its receptor.
  8. Motorola XOOM 2 Media Edition Touch Screen Replacement: 8 단계, 이미지 1/2 Motorola XOOM 2 Media Edition Touch Screen Replacement: 8 단계, 이미지 2/2
    • Use a plastic opening tool to gradually separate the screen from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lacie Broten
회원 가입일: 09/28/16
271 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 636
