주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Xoom 2 Rear-Facing Camera Replacement
필요한 것
  1. Motorola Xoom 2 Rear-Facing Camera Replacement, Backplate: 1 단계, 이미지 3개 중 1개 Motorola Xoom 2 Rear-Facing Camera Replacement, Backplate: 1 단계, 이미지 3개 중 2개 Motorola Xoom 2 Rear-Facing Camera Replacement, Backplate: 1 단계, 이미지 3개 중 3개
    • Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
  2. Motorola Xoom 2 Rear-Facing Camera Replacement: 2 단계, 이미지 2개 중 1개 Motorola Xoom 2 Rear-Facing Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Using a T5 screwdriver, unscrew the four 1.5mm screws holding the main back cover. These screws are arranged in a line across the top of the back of the device.
  3. Motorola Xoom 2 Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 1개 Motorola Xoom 2 Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 2개 Motorola Xoom 2 Rear-Facing Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Turn the device over and using a pry tool and the opening picks, gently apply pressure between the outside edge of the seal marked with the arrow. Slowly move around the edges of the device, applying even pressure, and separate the back plate from the display.
    • There is adhesive between the back-plate and battery.
  4. Motorola Xoom 2 Rear-Facing Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back plate from your device.
  5. Motorola Xoom 2 Rear-Facing Camera Replacement, Rear-Facing Camera: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, remove the blue Kapton tape.
    • Set this piece aside as it is required for reassembly.
  6. Motorola Xoom 2 Rear-Facing Camera Replacement: 6 단계, 이미지 2개 중 1개 Motorola Xoom 2 Rear-Facing Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Using a spudger, carefully pry and remove camera assembly using the small pry point as shown.
    • After removing the camera from the housing, use tweezers and pull gently to remove the connector from its housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ryan Bergeron
회원 가입일: 09/23/19
103 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 31
전체 시간: 291
