주요 콘텐츠로 건너뛰기
Motorola Xoom 2 Speaker Replacement
필요한 것
  1. Motorola Xoom 2 Speaker Replacement, Backplate: 1 단계, 이미지 1/3 Motorola Xoom 2 Speaker Replacement, Backplate: 1 단계, 이미지 2/3 Motorola Xoom 2 Speaker Replacement, Backplate: 1 단계, 이미지 3/3
    • Pry off the silver top back cover (the panel around the camera) with iFixit opening picks or a similar implement.
  2. Motorola Xoom 2 Speaker Replacement: 2 단계, 이미지 1/2 Motorola Xoom 2 Speaker Replacement: 2 단계, 이미지 2/2
    • Using a T5 screwdriver, unscrew the four 1.5mm screws holding the main back cover. These screws are arranged in a line across the top of the back of the device.
  3. Motorola Xoom 2 Speaker Replacement: 3 단계, 이미지 1/3 Motorola Xoom 2 Speaker Replacement: 3 단계, 이미지 2/3 Motorola Xoom 2 Speaker Replacement: 3 단계, 이미지 3/3
    • Turn the device over and using a pry tool and the opening picks, gently apply pressure between the outside edge of the seal marked with the arrow. Slowly move around the edges of the device, applying even pressure, and separate the back plate from the display.
    • There is adhesive between the back-plate and battery.
  4. Motorola Xoom 2 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the back plate from your device.
  5. Motorola Xoom 2 Speaker Replacement, Speaker: 5 단계, 이미지 1/2 Motorola Xoom 2 Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Using tweezers or a prying tool, gently disconnect the speaker connector cable from the motherboard.
    • Check to make sure that red is on the right and black is on the left.
  6. Motorola Xoom 2 Speaker Replacement: 6 단계, 이미지 1/2 Motorola Xoom 2 Speaker Replacement: 6 단계, 이미지 2/2
    • Using a prying tool or a spudger, gently apply pressure to the gap between the speaker and the plastic chassis and lift the speaker out of the device.
    • The speakers are held in place by a piece of tape.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Enrique Escobar
회원 가입일: 09/24/19
486 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 79
