주요 콘텐츠로 건너뛰기
Motorola Xoom Wifi Battery Replacement
필요한 것
  1. Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: 1 단계, 이미지 1/2 Motorola Xoom Wifi Battery Replacement, Back Cover Disassembly: 1 단계, 이미지 2/2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Battery Replacement: 2 단계, 이미지 1/2 Motorola Xoom Wifi Battery Replacement: 2 단계, 이미지 2/2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Battery Replacement: 3 단계, 이미지 1/3 Motorola Xoom Wifi Battery Replacement: 3 단계, 이미지 2/3 Motorola Xoom Wifi Battery Replacement: 3 단계, 이미지 3/3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Battery Replacement, Battery: 4 단계, 이미지 1/2 Motorola Xoom Wifi Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the two battery leads with a T-5 Torx screwdriver.
    • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
  5. Motorola Xoom Wifi Battery Replacement: 5 단계, 이미지 1/2 Motorola Xoom Wifi Battery Replacement: 5 단계, 이미지 2/2
    • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
    • The battery should lift out easily.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Andrew Mercier
회원 가입일: 04/14/14
532 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014 회원
CPSU-MANESS-S14S3G39
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
does anyone know what the function of the black and red wires are? my connector came off the motherboard.
Duli - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 4,548
