주요 콘텐츠로 건너뛰기
Motorola Xoom Wifi Speakers Replacement
필요한 것
  1. Motorola Xoom Wifi Speakers Replacement, Back Cover Disassembly: 1 단계, 이미지 1/2 Motorola Xoom Wifi Speakers Replacement, Back Cover Disassembly: 1 단계, 이미지 2/2
    • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
  2. Motorola Xoom Wifi Speakers Replacement: 2 단계, 이미지 1/2 Motorola Xoom Wifi Speakers Replacement: 2 단계, 이미지 2/2
    • Apply light pressure with hand and slide the back plate till it stops in this position.
    • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
    • As soon as the clips are released the back should slide off.
  3. Motorola Xoom Wifi Speakers Replacement: 3 단계, 이미지 1/3 Motorola Xoom Wifi Speakers Replacement: 3 단계, 이미지 2/3 Motorola Xoom Wifi Speakers Replacement: 3 단계, 이미지 3/3
    • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
    • Once both screws are taken out, lift the rest of the backing out of the way.
  4. Motorola Xoom Wifi Speakers Replacement, Speakers: 4 단계, 이미지 1/2 Motorola Xoom Wifi Speakers Replacement, Speakers: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
    • Replace speaker if necessary.
결론
Mallika
회원 가입일: 04/20/14
464 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014 회원
CPSU-MANESS-S14S3G39
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 242
