주요 콘텐츠로 건너뛰기
Motorola g stylus battery Replacement
필요한 것
  1. Motorola g stylus battery Replacement, remove  the sims card and tray: 1 단계, 이미지 2개 중 1개 Motorola g stylus battery Replacement, remove  the sims card and tray: 1 단계, 이미지 2개 중 2개
    • Use your sim card eject tool to remove the sim card and tray.
  2. Motorola g stylus battery Replacement, remove stylus: 2 단계, 이미지 1개 중 1개
    • Remove your stylus pen from the phone.
  3. Motorola g stylus battery Replacement, removing the back of your phone: 3 단계, 이미지 3개 중 1개 Motorola g stylus battery Replacement, removing the back of your phone: 3 단계, 이미지 3개 중 2개 Motorola g stylus battery Replacement, removing the back of your phone: 3 단계, 이미지 3개 중 3개
    • Using your heat gun or a hairdryer heat the back of the phone to loosen up the adhesive.
    • Now using your opening devices go along the edge of the phone slow and easy prying along the edges till they're loose.
    • As you're lifting up the back of your phone be sure you watch out for the fingerprint scanner, just keep it pushed down while you're lifting up the back of the phone .
  4. Motorola g stylus battery Replacement, top and botttom inside covers: 4 단계, 이미지 2개 중 1개 Motorola g stylus battery Replacement, top and botttom inside covers: 4 단계, 이미지 2개 중 2개
    • Here you will have 15 t4 screws on top and bottom to take out but be careful with the top cover because the finger sensor runs under it. You don't want to rip that
  5. Motorola g stylus battery Replacement, Removing the battery: 5 단계, 이미지 1개 중 1개
    • Here we need to be careful that we don't damage the battery, so unhook the battery and its flex cable. Then carefully get one corner of the battery lifted up to where you can get a good grip to pull on it. You will have to pull it slower so you don't damage the battery once that is done you made it.
    • New line.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Trent Weaver
회원 가입일: 09/16/20
232 평판
안내서 1개를 작성함
댓글 2개
Yessir, you the man bro
0% 100% - 답글
The image appears to be the Moto G Stylus 2021 model. Are the 2022, 2023, and 2024 models similar to the 2021 model?
e s - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 94
전체 시간: 8,757
