주요 콘텐츠로 건너뛰기
Motorola i1000plus Back Cover Replacement
필요한 것
  1. Motorola i1000plus Back Cover Replacement, Battery: 1 단계, 이미지 1/3 Motorola i1000plus Back Cover Replacement, Battery: 1 단계, 이미지 2/3 Motorola i1000plus Back Cover Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure phone is powered off before removing the battery.
    • Push the tab located at the bottom of the battery towards the top of the phone.
    • Lift the battery away from the phone.
  2. Motorola i1000plus Back Cover Replacement, Antenna: 2 단계, 이미지 1/3 Motorola i1000plus Back Cover Replacement, Antenna: 2 단계, 이미지 2/3 Motorola i1000plus Back Cover Replacement, Antenna: 2 단계, 이미지 3/3
    • Grasp the antenna between two fingers and turn it counterclockwise until it is unscrewed.
    • Pull the antenna straight out of the phone.
  3. Motorola i1000plus Back Cover Replacement, Back Cover: 3 단계, 이미지 1/3 Motorola i1000plus Back Cover Replacement, Back Cover: 3 단계, 이미지 2/3 Motorola i1000plus Back Cover Replacement, Back Cover: 3 단계, 이미지 3/3
    • Pry off the bottom piece using the spudger.
    • There are notches on the edge of this piece that can be used to aid prying.
  4. Motorola i1000plus Back Cover Replacement: 4 단계, 이미지 1/1
    • Remove the sticker overlaying the NEXTEL logo.
  5. Motorola i1000plus Back Cover Replacement: 5 단계, 이미지 1/1
    • Using a Torx T8 screwdriver, remove the two screws exposed after removing the sticker by unscrewing counterclockwise.
  6. Motorola i1000plus Back Cover Replacement: 6 단계, 이미지 1/3 Motorola i1000plus Back Cover Replacement: 6 단계, 이미지 2/3 Motorola i1000plus Back Cover Replacement: 6 단계, 이미지 3/3
    • Starting from the bottom and working towards the top, use a spudger to pry the back cover off the phone.
결론
Austin Lake
회원 가입일: 10/18/13
501 평판
안내서 5개 작성하였습니다
Clemson, Team 13-3, Benson Fall 2013 Clemson, Team 13-3, Benson Fall 2013 회원
CLEM-BENSON-F13S13G3
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 197
