소개
The antenna greatly affects the quality of the phone's reception.
  1. Place the phone on a flat surface with the front facing down and the antenna fully extended. Use a spudger to remove the circular rubber cover from the base of the antenna. Remove the 3.2 mm Torx T5 screw located under the rubber cover.
    • Place the phone on a flat surface with the front facing down and the antenna fully extended.
    • Use a spudger to remove the circular rubber cover from the base of the antenna.
    • Remove the 3.2 mm Torx T5 screw located under the rubber cover.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone. Do not grasp the black antenna piece to pull it out. Doing so may damage it. Do not grasp the black antenna piece to pull it out. Doing so may damage it.
    • Remove the antenna by grasping from the white plastic piece just below the antenna and pulling away from the phone.
    • Do not grasp the black antenna piece to pull it out. Doing so may damage it.
결론
Garrison Stevens
회원 가입일: 2012년 10월 22일
1 평판
안내서 6개 작성하였습니다
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 회원
CLEM-BENSON-F12S15G2
4 회원들
안내서 16개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 322
