소개
The battery allows the phone to operate without needing to be plugged into a power outlet at all times.
도구
No tools specified.
부품
No parts specified.
  1. Place the phone on a flat surface with the front facing down. Insert your finger under the gray plastic cover at the bottom end of the phone. Lift the cover off the phone.
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  3. Place your thumb in the notch in the lower left corner of the battery compartment. Lift the battery up and away from the phone. Remove the battery.
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
결론
Garrison Stevens
회원 가입일: 2012년 10월 22일
1 평판
안내서 6개 작성하였습니다
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 회원
CLEM-BENSON-F12S15G2
4 회원들
안내서 16개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 508
