주요 콘텐츠로 건너뛰기
Motorola i450 Boost Mobile Headphone Port Replacement
필요한 것
  1. Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Headphone Port Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Headphone Port Replacement, Battery: 2 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: 2 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Headphone Port Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: 3 단계, 이미지 2개 중 1개 Motorola i450 Boost Mobile Headphone Port Replacement, SIM Card: 3 단계, 이미지 2개 중 2개
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Headphone Port Replacement: 4 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Headphone Port Replacement: 4 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Headphone Port Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Headphone Port Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Headphone Port Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Headphone Port Replacement: 7 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Headphone Port Replacement: 7 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Headphone Port Replacement: 7 단계, 이미지 3개 중 3개
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  8. Motorola i450 Boost Mobile Headphone Port Replacement, Headphone Port: 8 단계, 이미지 1개 중 1개
    • Locate the headphone port at the bottom right corner of the circuit board.
    • The headphone port cannot be removed from the phone. If cleaning the port does not fix the problem, the entire phone must be replaced.
결론
작성자
5다른 기여자 명과 함께
Garrison Stevens
회원 가입일: 10/22/12
1 평판
안내서 6개를 작성함
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 회원
CLEM-BENSON-F12S15G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 484
