주요 콘텐츠로 건너뛰기
Motorola i450 Boost Mobile Keypad Replacement
필요한 것
  1. Motorola i450 Boost Mobile Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Keypad Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Place the phone on a flat surface with the front facing down.
    • Insert your finger under the gray plastic cover at the bottom end of the phone.
    • Lift the cover off the phone.
  2. Motorola i450 Boost Mobile Keypad Replacement, Battery: 2 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Keypad Replacement, Battery: 2 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Keypad Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Place your thumb in the notch in the lower left corner of the battery compartment.
    • Lift the battery up and away from the phone.
    • Remove the battery.
  3. Motorola i450 Boost Mobile Keypad Replacement, SIM Card: 3 단계, 이미지 2개 중 1개 Motorola i450 Boost Mobile Keypad Replacement, SIM Card: 3 단계, 이미지 2개 중 2개
    • Locate the metal slider that holds the SIM card in place.
    • Push the slider away from the metal flap which contains the SIM card. The flap will pop up.
  4. Motorola i450 Boost Mobile Keypad Replacement: 4 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Keypad Replacement: 4 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Keypad Replacement: 4 단계, 이미지 3개 중 3개
    • Lift the metal flap to gain access to the bottom of the SIM card.
    • Remove the SIM card by sliding it out parallel to the bottom of the flap.
  5. Motorola i450 Boost Mobile Keypad Replacement, Circuit Board: 5 단계, 이미지 1개 중 1개
    • Extend the antenna.
  6. Motorola i450 Boost Mobile Keypad Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 4.8 mm Torx T6 screws from the corners of the back of the phone.
    • If the antenna is not fully extended, the top left screw will not be accessible.
  7. Motorola i450 Boost Mobile Keypad Replacement: 7 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Keypad Replacement: 7 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Keypad Replacement: 7 단계, 이미지 3개 중 3개
    • Gently lift off the back half of the phone and set to the side.
    • Permanent circuit connections prevent the cover from completely separating from the phone. Do not attempt to disconnect these circuits.
  8. Motorola i450 Boost Mobile Keypad Replacement, Keypad: 8 단계, 이미지 3개 중 1개 Motorola i450 Boost Mobile Keypad Replacement, Keypad: 8 단계, 이미지 3개 중 2개 Motorola i450 Boost Mobile Keypad Replacement, Keypad: 8 단계, 이미지 3개 중 3개
    • Gently lift the end of the circuit board farthest from the phone hinge.
    • The circuit board is permanently connected to the phone casing at the end nearest to the hinge.
    • Grasp the keypad at the bottom of the phone, raise it, and pull it away.
결론
작성자
5다른 기여자 명과 함께
Garrison Stevens
회원 가입일: 10/22/12
1 평판
안내서 6개를 작성함
Clemson, Team 15-2, Benson Fall 2012 Clemson, Team 15-2, Benson Fall 2012 회원
CLEM-BENSON-F12S15G2
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 544
