주요 콘텐츠로 건너뛰기
Motorola i560 Metal Support Plate Replacement
필요한 것
  1. Motorola i560 Metal Support Plate Replacement, Battery: 1 단계, 이미지 1/1
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Motorola i560 Metal Support Plate Replacement: 2 단계, 이미지 1/1
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Motorola i560 Metal Support Plate Replacement, Side Volume Button: 3 단계, 이미지 1/1
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. Motorola i560 Metal Support Plate Replacement: 4 단계, 이미지 1/1
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  5. Motorola i560 Metal Support Plate Replacement: 5 단계, 이미지 1/2 Motorola i560 Metal Support Plate Replacement: 5 단계, 이미지 2/2
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  6. Motorola i560 Metal Support Plate Replacement: 6 단계, 이미지 1/2 Motorola i560 Metal Support Plate Replacement: 6 단계, 이미지 2/2
    • Detach the first ribbon cable by unplugging it from the logic board.
  7. Motorola i560 Metal Support Plate Replacement: 7 단계, 이미지 1/3 Motorola i560 Metal Support Plate Replacement: 7 단계, 이미지 2/3 Motorola i560 Metal Support Plate Replacement: 7 단계, 이미지 3/3
    • Gently remove the side button by pulling the buttons away from the phone.
  8. Motorola i560 Metal Support Plate Replacement, Metal Support Plate: 8 단계, 이미지 1/3 Motorola i560 Metal Support Plate Replacement, Metal Support Plate: 8 단계, 이미지 2/3 Motorola i560 Metal Support Plate Replacement, Metal Support Plate: 8 단계, 이미지 3/3
    • Grab the tab at the bottom of the metal plate, and pull to remove the plate from the phone.
결론
Haley S
회원 가입일: 03/11/13
10 평판
안내서 4개 작성하였습니다
Clemson, Team 13-6, Benson Spring 2013 Clemson, Team 13-6, Benson Spring 2013 회원
CLEM-BENSON-S13S13G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 13
전체 시간: 135
