소개
The side volume button installation guide will require removal of the battery to access the location of the side volume button. This guide can be used to replace damaged volume buttons.
부품
No parts specified.
  1. Place thumb on the rubber tab on the lower back of the phone.
    • Place thumb on the rubber tab on the lower back of the phone.
    • Push away from the phone to release back panel.
  2. Lift the back panel of the phone to expose battery (not shown here).
    • Lift the back panel of the phone to expose battery (not shown here).
  3. Pull antenna up, away from the phone, to reveal two of six screws.
    • Pull antenna up, away from the phone, to reveal two of six screws.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
    • Unscrew all six 5.4 mm screws on the back side of the phone using the T-6 screwdriver bit.
  6. Gently separate the front and back sides of the phone. Be careful not to break or bend the ribbon cables.
    • Gently separate the front and back sides of the phone.
    • Be careful not to break or bend the ribbon cables.
  7. Detach the first ribbon cable by unplugging it from the logic board. Detach the first ribbon cable by unplugging it from the logic board.
    • Detach the first ribbon cable by unplugging it from the logic board.
  8. Gently remove the side button by pulling the buttons away from the phone. Gently remove the side button by pulling the buttons away from the phone. Gently remove the side button by pulling the buttons away from the phone.
    • Gently remove the side button by pulling the buttons away from the phone.
결론
Haley S
회원 가입일: 2013년 03월 11일
10 평판
안내서 4개 작성하였습니다
Clemson, Team 13-6, Benson Spring 2013 Clemson, Team 13-6, Benson Spring 2013 회원
CLEM-BENSON-S13S13G6
3 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 116
